Can you convert a Tweco no.2 gun to use No.4 h/duty screw on nozzles?
发表于 2021-8-31 22:48:10 | 显示全部楼层 |阅读模式
I have a Tweco no.2 gun that has the push on nozzles and 11 series tips.  All the other guns are no.4 with the heavy duty screw on nozzles (24CT-62S) and the screw on insulator, and use the 14H-35 tips.Can you convert the smaller gun over to use the no4 parts?Will a no.4 neck fit inside the handle of a no.2 gun?  if so I should then be able to use the larger parts?
Reply:Old SP85 lincoln has push on stuff. Was able to convert the forward gun/tube, so I could use screw on.Welding shop recommended a new tweco gun, about $120. Depends, new welder, keep old 110 volt SP85.Mainly use SP85 for .020 wire, thin stuff.Big mig uses .030 wire, thick stuff.Charl
Reply:Can you post a pic of the both guns and the consumables you speak of?Look anything like these pics?http://webpages.charter.net/akelliott/100_1826.JPGhttp://webpages.charter.net/akelliott/100_1831.JPGLast edited by polarred21; 04-29-2013 at 12:51 AM.
Reply:yeah those are the guns except we have the heavy duty nozzles
Reply:By using a 52FN diffuser you can use either 34CT/24CT-?? insulator/nozzle combo or 23series nozzles and 14 series tips.
Reply:Yes that part looks like it might work.  Thank you.
GMT+8, 2025-12-29 16:29 , Processed in 0.103920 second(s), 18 queries .
