tube bender wanted
发表于 2021-8-31 22:48:07 | 显示全部楼层 |阅读模式
I'm looking for a good used tube bender JD2 style or even something somebody's built. the die i will need is 1.25 and do a 4.5 radius,thanks PM me price and info. Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Look on Dezertrangers.com. There are benders on there all the time.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Check this out- just saw it on another post/forum- rolxtools.com
GMT+8, 2025-12-29 14:49 , Processed in 0.064454 second(s), 18 queries .
