查看: 13|回复: 0
Large brazing rods
发表于 2021-8-31 22:48:00 | 显示全部楼层 |阅读模式
I have a box of brazing rods that I have had for about 15 years now. I know welding supplies have gone up and was wondering if anyone could tell me how much they are worth. They are 5/16 in. in diameter. 36 in. long. I have about 50 sticks and I havent used any for a long time.  They are big for welding on small stuff but I bought them for a different project. I hope I have this in the right place. Thanks Harold
Reply:More information needed,What alloy, are the rods coated or bareJohn
Reply:I guess not sure of alloy. Box was bad couldnt find anything on it.  Bare rods.
Reply:I guess nobody uses big brazing rods. Guess I will build a 3 ft windmill out of some of them.
Reply:Large brazing rods are pretty much a lot art now days. I do use them but not in large quantities. I've normally topped out at 1/4" but if I knew they where low fuming bronze then I might be interested for the right price.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I use as large as 3/8".http://www.facebook.com/LockhartMetalArthttp://www.facebook.com/pages/Grumpy...44306259043484
Reply:If you ever get into a propeller shop that does big bronze wheels, they use pretty good sized stuff (1/2 square or maybe a bit bigger)Experience is something you get right after you need it
Reply:Irish fixit. I have no way of knowing what these are. I bought them for repairing aerators that needed a 5/16 rod about 12 inches long. I just ordered the cheap regular rods. I had to order a full box to get them that size .
Reply:Likely low fuming brass but no way of really knowing. The only way I would know is if I tried using them on cast iron. I've got some that I believe are silicon bronze since they work well with TIG but if I use them with a torch on cast iron I end up burning the cast iron till it won't take the bronze before getting it melted properly.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
GMT+8, 2025-12-29 15:09 , Processed in 0.072225 second(s), 18 queries .
