Hello...First post.I was given as a gift the portable Spectrum 625 x-treme plasma cutter,with the option to exchange if not what I want. It is to replace my Lincoln Pro 55.I have never used one the small portable cutters, and wonder if I should keep it, or exchangefor the stationary Spectrum 875, which is more like what I was using. I mostly cut sheet, up to 3/8 plate...and every once in a while 1/2 inch plate. Cost is not an issue and I do not need a portable to take out on job sites. Should I keep the little box, or exchange? Thank you.
Reply:Originally Posted by julesHello...First post.I was given as a gift the portable Spectrum 625 x-treme plasma cutter,with the option to exchange if not what I want. It is to replace my Lincoln Pro 55.I have never used one the small portable cutters, and wonder if I should keep it, or exchangefor the stationary Spectrum 875, which is more like what I was using. I mostly cut sheet, up to 3/8 plate...and every once in a while 1/2 inch plate. Cost is not an issue and I do not need a portable to take out on job sites. Should I keep the little box, or exchange? Thank you.
Reply:Thank you for the reply. I leaning towards keeping it.
Reply:I also looked into the 625 seems to be a great machine and if you have a bigger one already at shop I'd personally would keep the 625 I know u said you don't need something portable but if you ever did you'd have it |
