type steel needed
发表于 2021-8-31 22:47:59 | 显示全部楼层 |阅读模式
I am going to help my neighbor repair his wood heater and the damper shaft needs to be replaced . the shaft is made of .5 inch round stock.My question is ,what type of steel ?   Elevated temperatures for an extended period should be a primary concern. because of the extreme heat and slow cooling I don't believe temper would be of any benefit. Any one have any experience in this area ?ThanksTom
Reply:Use stainless steel.  http://www.azom.com/article.aspx?ArticleID=1175"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Is this an outdoor wood fired hot water heater? If so, the damper/solenoid/connecting rod does not come in direct contact with the fire/creosol of the fire box.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-29 14:49 , Processed in 0.101833 second(s), 18 queries .
