Zoro 30% off
发表于 2021-8-31 22:47:58 | 显示全部楼层 |阅读模式
Today only 30% off $200 or more ... 12/1/14 http://www.zoro.com/ Code: HOLIDAYLast edited by GlenC; 12-01-2014 at 09:24 AM.GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:"Got my spreadsheet all saved up for a begginer welder.  Here's some info if yall are looking for something specific: Item                                       Part Number              CostPipeliner Helmet                       G0946845                    48.5Gold lens                               G1522516                       9Ratchet Helmet Gear               G4331923                      19Tillman Stick Gloves               G0130453                      163m 7500 Half Mask Large             G2729203                      223m P100 Filters 2297 2x sets       G3313353                      213m Face Shield                       G3201274                      25Estwing Chipping Hammer       G5288184                      27Dasco Center / Pin Punches       G4620341, G4564156, G4551942Wire Brush                               G3385794                      5Klein Scissors                            G3626691                          16.14Total                                213Total with discount 25%159.75Total with discount 30%149.1I know the formating sucks, but I can't get the spaces to work outLast edited by dklic6; 12-01-2014 at 11:12 AM.Reason: Format
Reply:I ordered the Dynabrade sander kit. Great buy for the money. http://www.zoro.com/g/Electric%20Abr.../00206369/None plus has FREE shipping too !Item: Electric Abrasive Belt Tool Belt Size (In.): 1/2 to 3/4 x 18 Includes: 40610 Electric Dynafile II with 11203 Contact Arm and 11202 and 11204 Contact Arms, (8)Abrasive Belts, Platen Pads
Reply:thanks, now I just have to figgure out what to buyI usually use mcmaster since their website is so easy to navigate, you can type in a lot of mcmaster part numbers into zoro and get equivalent parts if that helps!
Reply:Originally Posted by AluminumWelderthanks, now I just have to figgure out what to buyI usually use mcmaster since their website is so easy to navigate, you can type in a lot of mcmaster part numbers into zoro and get equivalent parts if that helps!
Reply:I just ordered a Fluke 568: http://www.zoro.com/i/G2756957/?category=6309and an assortment of Bernard nozzles for my MIG gun!GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Thanks, my order just shipped saved a lot on clamps!!!!Code:Z NumberItemQuantityUnitsDescriptionShippingRateAmountG8495541Welding Table Clamp Kits4EATable Mount Clamp, Depth 3-3/8 In, Width 4 In, Height 12 In,                  For Use With BuildPro Welding Tables, Load Capacity 250 lbs. G2269531Single Flute Counter SinksGeneral Purpose-HSS                4EACountersink, Single Ended, Number of Flutes 1, Included Angle 82 Deg, Body Dia 1/2 In, Shank Dia 1/4 In, Shank Length 1 In, Overall Length 2 In, High Speed SteeG1665797C-Clamp, w/ Swivel Pad3EALocking C-Clamp w/Swivel Pad, C-Clamp, 8 In.,                  Capacity 2-1/2 In., Throat Depth 2-1/4 In., Jaw Width 27/32 In., Locking Mechanism Automatic, Pliers Length 8-1/4 In., Nickel Plated, Alloy SteelG5150187Clamp, Toggle8EAAuto-Adjust Toggle Clamp, Horizontal Closing/Base, U Channel Arm, Holding Capacity (Lb.) 450, Height Under Arm (In.)                 3/4, Overall Height (In.) 1-3/4, Overall Length (In.) 6-1/2, Dia. (In.) 9/16, Base Mounting Centers (In.) 1 x 1-1/8 and 1/2 x 1-1/8, Handle Ergonomic,                  Molded, 2-Component, Thread Size M6, Spindle Steel, Construction Formed and Welded Steel, Includes Plastic Protective Cap, Application For Work Holding G8495627Inserta Clamps5EAInserta Clamp, Height 1/2 In, Width 8-1/2 In, Depth 4 In, For Use With BuildPro Welding Tables, Load Capacity 400 lbs.,                   Includes 1 pc. Threaded AdaptorExpedited Shipping Available23.22116.10G81119052-1/2" x 1" x 1" Ball Lock Bolts2EABall Lock Bolt, Height 2-1/2 In, Width 1 In, Depth 1 In, For Use With BuildPro Welding Tables Subtotal536.29Discount (Partner Discount)-160.89Shipping Cost (Standard Ground)0.00Total Tax26.27Total$401.67
Reply:I placed my order on  Monday AM and received it today ! Zoro is in a suburb near me.
Reply:Bastard!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:I got a millermatic 211 for $887 and a spoolmate 100 for $180 Welding/Fab Pics: www.UtahWeld.com
Reply:they have a nice fien mag drill I noticed as well maybe next time.
Reply:You can never have too many clamps!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by MikeGyverI got a millermatic 211 for $887 and a spoolmate 100 for $180
Reply:As the word spreads, there will probably be a lot of new Blue & Red units sold....Time for wish lists!Sent from my SM-G900V using TapatalkGlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Originally Posted by GlenCAs the word spreads, there will probably be a lot of new Blue & Red units sold....Time for wish lists!Sent from my SM-G900V using Tapatalk
Reply:GlenC thanks for mentioning that. I ordered 4 sumner jack stands and already received them today. They don't play when it comes to shipping. Not to mention I saved a heap of $. Again thanks.
Reply:Glad to help!  It's great to get big discounts on quality tools! Just need to research each item...My Fluke 568 IR Thermometer‎ and MIG gun parts arrive tomorrow! GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Originally Posted by honestAKMe too!  Hasn't shipped yet...Plus we still get the 100 dollar rebate!
Reply:Originally Posted by MikeGyverlol really? awesome.I only know a little about this, got any more info?
Reply:It's back for today!30% off your order—maximum savings of $2,000. Enter SAVENOW30 at checkout. Limit one (1) use per customer. May not be combined with any other promotions or discounts. Offer may not be applied to previous purchases. No order minimum required. Offer valid Monday, December 29, 2014 from 9am to 3pm CT.
Reply:Yes, I got the email and had to restrain myself. Only spent $70 on belts for the Dynabrade belt sander I bought on the last sale.
Reply:Oh yes!!  I bought a Miller Digital Elite Helmet in Black!  I saved $90.00 with the 30% off code.  Now, I'll turn in the Miller rebate form for another $70.00 off.  !!My total for the helmet will be $143.00 and I am happy about it.I really have no idea what I am doing.Two Shop Cats (not Bobcats...real cats)Miller DialArc 250 AC/DCScratch-Start TIG SetupMIG 175Plasma CutterO/A
Reply:Originally Posted by soutthpawA dynasty 200dx for under $3000!
Reply:Originally Posted by OscarIts funny you should say that.  With the 30% discount it comes out to $2907, yet there is one 5yrs old on eBay for $3000
Reply:I checked with my lws and the 1800 I spent on the 252 was about 300 below their cost.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch coolerDidn't realize it was only till 3 CT.  Guess I'm just emptying my cart.
Reply:Originally Posted by sacherjjDidn't realize it was only till 3 CT.  Guess I'm just emptying my cart.
Reply:almost bought the magnetic benderhttp://www.zoro.com/g/Electromagneti.../00206116/Nonebut I guess i'm too late.
GMT+8, 2025-12-29 14:57 , Processed in 0.141458 second(s), 18 queries .
