Short hood F-162 year?
发表于 2021-8-31 15:02:09 | 显示全部楼层 |阅读模式
I have a 1945 Short hood with the F-162. It has a rebuild tag on the block from Lincoln Electric Date stamped "12-53", bored out 0.040, STD Main and Rod journals, with the serial # 31370. The engine block is also stamped 31370, but on the right side of the block has a date 1-16-Q. I called Montes Equipment and they said it was a 1965 engine. Doesn't really make since being that the rebuild tag has Dec 1953 on it. Attached ImagesSA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:found lot block dates on top head usually in center closes water neck near firing order,, may strip some paint
Reply:Here is the head cast date: F-4-7 . I have tried to figure out that if F= June, 4th day, 7= 47 ? Attached ImagesSA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
GMT+8, 2025-12-18 16:10 , Processed in 0.087613 second(s), 18 queries .
