LWS error.. help with tig filler, 5356
发表于 2021-8-31 22:47:53 | 显示全部楼层 |阅读模式
I have a job to do tomorrow, Sunday.  There isn't a welding shop open in town. I bought 10lbs of 5356 filler to tig weld two brackets.  I opened the box this afternoon and its 1/8" not 1/16".....One bracket is 1/8 thick aluminum, the other is 7/16" round bar. I'm using a Danasty 200. I'm new to aluminum but have a fair amount of experience with stainless and mild steel. I tried to weld with this rod today and its about what I expected, way to thick. Any advice on what to do?
Reply:Some lowes or Home Depot carry 1 lb spools of 035 wire. You can twist a few strands to make it thicker.
Reply:Perhaps a higher than normal pulse with a simultaneous dab of the filler to equalize the extra heat input? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:If you had your location noted, someone might be willing to spot you some if you were sort of near by. Pays some times to have your location listed in your User CP..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I'm in Edmonton Albeta.Thanks for the tip...If there is anyone in the city I would appreciate it.
Reply:Bummer. I would have suggested 3/32" diameter, but I think I would be able to use 1/8th in a pinch. You will have to melt the puddle larger before chilling it with the filler. Up your cup size and gas flow.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Grab a clean hammer and hammer it flat. It will require less heat to get it to melt. Works in a pinch. Just make sure hammer and surface it's on for flattening are clean as it will totally contaminate the rod
GMT+8, 2025-12-29 14:57 , Processed in 0.103305 second(s), 18 queries .
