Can I TIG with a SA200
发表于 2021-8-31 22:47:50 | 显示全部楼层 |阅读模式
So I was wondering. Can I buy a tig torch and use my argon bottle off my mig welder hhok it up DCEN to my Lincoln and TIG steel? Someone told me the other day you cannot tig with a SA200 like this. Just not sure whay you could not simply adjust your current at the SA200 and scratch or touch start. Have your gas control on the tig torch . You would not have a pedal to adjust current, nor pre /  post gas like some machines have.... Just wondering. I currently am taking a TIG class and we do not hace foot pedals we adjust at the box and touch start so what would be the difference?EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:I do it all the time.Here is a link that will show you everything you need. http://weldingweb.com/vbb/showthread.php?t=57918Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:CAN I TIG WITH A SA200Well it will be a little heavy to hold  I would use a wp26 torch it is easyer to hold www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by mechanic416CAN I TIG WITH A SA200Well it will be a little heavy to hold  I would use a wp26 torch it is easyer to hold
Reply:mechanic 416 I am trying to build my biceps EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:I had a pedal wired in series with the rheostat on the face of the sa200.  Put a socket into the sheet metal and a plug with the two terminals on the pedal plug going to the rheostat commected for normal use.  Same pedal as for my dinosaur transformer welder.  It was a gasoline hog and I let someone talk me into selling it to them.  I didn't use it much but it worked quite nicely for my purposes.
Reply:hey frank how did you rig that up
GMT+8, 2025-12-29 14:48 , Processed in 0.071667 second(s), 18 queries .
