Filler panel for security gate.
发表于 2021-8-31 22:47:43 | 显示全部楼层 |阅读模式
Buddies girlfriend lives in a bit of a rough neighborhood. He got her a gate to go between the house and garage but it was a bit too narrow. This is what we came up with.Frame is 1/8" 1x1 square tube and 1/8" 1x1 angle (to bolt to the garage) Two 3/8" round bar running up the center and 5/32" 7018 rods (with the flux knocked off) as cross pieces. Barely visible is the letter "M" I cut for the front from 16ga aluminum. Redneck CNC style. Find image online, blow up to size on copier, make stencil, trace stencil, cut on band saw, file rough edges. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:I like the use of rods for design but I really like the way your redneck CNC works! Mine is getting better with practice. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Rough = code name for ghetto.No wonder gangsters call eachother "dogg". They are from a ruff neighborhood...Sorry, to easy. Nice fix though.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerRough = code name for ghetto.No wonder gangsters call eachother "dogg". They are from a ruff neighborhood...Sorry, to easy. Nice fix though.
Reply:Originally Posted by Mick120Good job Larp....You missed the spikes along the top tho...... ...
Reply:Looks like a ladder to me.What keeps them from just going over ?How about cladding the outside side with thin sheet to stop that ?
Reply:Originally Posted by 12345678910Looks like a ladder to me.What keeps them from just going over ?How about cladding the outside side with thin sheet to stop that ?
Reply:Add Spikes, make that 10" into 4".There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by larpheadFrom what I understand it is like a breezeway. There is only about a 10" opening at the top
GMT+8, 2025-12-29 14:48 , Processed in 0.099194 second(s), 18 queries .
