Gym Equipment # 8 Compact Pulling SledA friend of mine started his own gym and asked me to make him some equipment. His gym floor space is very small so I stole this idea from an established producer.The plate is 3/8 thick and was part of my old welding table. I made all cuts (the longest 49) with a Sawzall!!! The other stuff in the picture is a set of bumper stackers and a few of the paralletts. Attached ImagesDave ReberWadsworth Ohio
Reply:That is cool. How did you bend the base plate?Jeff
Reply:Thanks jdog I have a press from harbor freight and brake. Here is the link to the press brake http://www.swagoffroad.com/20-TON-Pr...Kit-_p_42.htmlDave ReberWadsworth Ohio
Reply:Reebs, this is turning into a fairly lucrative side gig for you. Nice work.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Thor thanks,Problem is I don't charge enough so I'm not making much. I should kick my own ***.Dave ReberWadsworth Ohio
Reply:Very cool, looks good. Nice work Originally Posted by ReebsThe plate is 3/8 thick and was part of my old welding table. I made all cuts (the longest 49) with a Sawzall!!!
Reply:Whenever I have to do something at home like cut or bend a thick plate, I do it with Difficulty™. Professional amateurs know you can get it done with Difficulty™."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I am glad you posted this. I have requests to build this exact same thing, a pulling sled, and even a "farmers walk" bar set that accepts Olympic weights.I too am hoping this will become something for me as well. Do you think 3/8" plate is necessary for the skid or did you use it because it was what you had?
Reply:7A749, there's a call for you from the Patent and Trademark Office on line 3."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I had a "Harry Homeowner" type guy give me some grief as I was about to cut off a piece of 5/8" keyed shaft. Like it wouldn't do it or would take forever. A 10 Amp Porter-Cable reciprocating saw with a new blade - took about 5 seconds. Damn. "You were saying?""USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Mwalden3/8 plate is overkill 1/4" plate is probably what the doctor ordered, but 3/8 plate is what I had. It was part of my old welding table top.Sqznby and othersI knew the Sawzall part was going to get me a rash of **** but that is all I have to cut plate with. I originally cut a piece with with the plasma at school (but it was too wide for my bender to bend).I live pretty far from the school and the plasma was not really meant for 3/8 plate in the first place. Plus it gave the forearms a good work out.Dave ReberWadsworth Ohio
Reply:I think its awesome. I give you much credit, I would've drove to a local shop to have them shear it. I have debated about using my sawzall to do the same.How many blades did you go through?What blades did you use?
Reply:sqznby Thanks manI only used 2 blades. The brand was Milwaukee Blades TorchDave ReberWadsworth Ohio
Reply:Looks way too heavy! :-) :-)Nice work.
Reply:Not to hijack, I had some kids in class make a prowler sled for our weight program, could not believe what people charge for these products.As it was said before, we don't charge enough and now we have more work than we can handle.Awesome sled!Some blue machinesSome red machineslots of heavy steel |
