welding preferences
发表于 2021-8-31 22:47:40 | 显示全部楼层 |阅读模式
We have four or five lincoln diesel drives at work just curious as to what your preferred method of setting are ? Do u set the main dial say at your lower desired setting and run the fine tuner at the high end or do you put the main at the higher end and fine tune at lower , just curious.
Reply:It depends on whether you want to dig or stack metal and what position you are welding in. What model Lincolns do you have?
Reply:It's simple. Set the machine to where like how the puddle runs. Turn the dials till you get it where you want it.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I'm not 100% but I believe a couple are old pipeliners and some are classics
Reply:Originally Posted by gundog77It depends on whether you want to dig or stack metal and what position you are welding in. What model Lincolns do you have?
Reply:Sorry for all the questions I haven't been in 5 he stick welding field very long I've mig welded all my adult life
Reply:I have passed my 6g pipe with 7018 but I'm fixing to try to go pass my 3g 4g with 7018 stringers only allowed and mig 3g 4g flux core test to get hired at nuk plant.
Reply:Set the machine how you like to weld.No two weldors in this world weld exactly alike.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by DockMan30817I take it if you want a dig you run on high side of main amp setting with the lower on the tuner like for a root and run lower main amp setting with a higher fine tuner turned up for stacking stringers and such?
GMT+8, 2025-12-29 16:41 , Processed in 0.110548 second(s), 18 queries .
