Help identifying this machine
发表于 2021-8-31 22:47:40 | 显示全部楼层 |阅读模式
Need help identifying this machine.  What is it worth.  It has the Hercules L head gas engine in it.  Any information would be helpful Thanks Attached Images
Reply:Appears to be a mid to late 1940's SAE300 Lincoln.
Reply:You don't show the rest of it?BUT!I remember a Thread somewhere about an "Industrial Tractor" (Case maybe) that had an air compressor and welder on it for use as a "Tugger"  by the Maintenance Mechanics in a Factory setting.
Reply:Wow!Makes the old Miller AEAD200LE I am looking at look pristine.Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:Here is another picture. It is on a trailer. I cannot find any identification.  This is one of three gas powered welders lying around the farm. They have been sitting in the weather forever.
Reply:It's a Lincoln SAE for sure. On the right hand dial under the pointer should say SAE on the left and the amp rating on the right.
GMT+8, 2025-12-29 18:31 , Processed in 0.122861 second(s), 18 queries .
