need to buy yourself a x-mas gift???
发表于 2021-8-31 22:47:35 | 显示全部楼层 |阅读模式
so you need to buy x-mas gift for yourself. The milwaukee 8'' metal cutting saw, is awsome I picked one up a few weeks back at the local welding /steel yard for about $260. bucks a little spendy but, alot cheaper than a plasma cutter. I still want a plasma! blades are alittle pricey too about $50. to $60.bucks I think? have'nt bought any yet. Last night I broke out the new saw for the frist time. I started cutting up an old 250 gal. fuel oil tank for a smoker project. The thing cut throught 12 ga. like butter .Today I cut up a 2nd tank. I figure I've cut close to 65 feet of 12 ga. and still cuttin like the frist cut. The saw is like a wood saw, you can get a fence for rips or clamp a 2x4 or staight edge for a guide. Nice clean staight cuts no worrys about wraping. cool, dry cuts. Safty Glasses and ear plugs are a must,as they should be. to Milwaukee  to the 6370 metal sawDaye Attached Images
Reply:nice... How thick of material can this cut?
Reply:i need to buy myself a Tig welder and a bike dyno i need about 20 grand. maybe i NEED adopted by a rich familyhttp://kawispeed.com/ -moderator and tech deluxewww.myspace.com/trickortrack -cuz i have no life
Reply:The blade looks like a wood cutting blade, I've never seen that before.  Is it diamond coated?  And you say it cuts cool.  Wow.Does it chatter on the thinner sheet metal?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I got the evolution 9". works well with thinner stuf. <1/4"I have cut 3/8" with it, but so far it didnt cut an acceptable length with one blade to make it worth my while.Although it was a real nice cut. Better than any plasma cut.I see the milwakee has a black lever behind the blade is that for lifting the blade guard?unfortunatly mine doesnt have one which makes it hard to start a cut in the correct place on certain materials, like angle or box section.  G
Reply:Hi,  I'v got the Evolution chop saw with 14" blade, Cuts really fast and cool, TCT teeth have 3 different profiles So each tooth isn't doing a full cut, BRILLIANT!   Best regards  Gordon
Reply:Could you just put one of those evolution saw blade in a miter saw? How much dust does one of those carbide blades make? Chop saws are alright, but i always have to use a combination square to get acurate 45 cuts.....
Reply:Hi,  Evolution blade gives no dust at all,just quite large metal chips. You would have to check on revs etc if you tried to use a different machine,  Cheers  Gordon.
Reply:No, Wood style mitre/chop saws are not safe or powerful enough for this kind of work.  It must be engineered for cutting metalEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by Mustangousnice... How thick of material can this cut?
Reply:At our cnc shop we have a SteelMax Metal Cutting Saw! Its basically a chop saw with carbide tipped blades versus abrasive blades. Available at AirGas and the price is not cheap at $499.99 with blades going from $97-$148 each.Personally I can get almost as fine a cut using my Hypertherm PowerMax 45 Plasma Cutter. An the plasma cutter is ALOT faster and cheaper in the longrun versus replacing those carbide blades.we also have a JET Metal Cutting Band Saw.Last edited by specter; 12-15-2008 at 02:28 PM.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:thanks alot for the info. I thing i know what my next tool will be. Do you know  where its made?"The Name of Jesus is a lightning rod because The Name represents the division of life between good and evil, God and Satan, light and darkness, righteousness and sin, heaven and hell"
Reply:I bough my self an grinder (http://www.metabo.co.uk/Product-cata...3496bc4.0.html) which comes at price of 325USD ¤If you got money, i've got time
Reply:I guess the Admiral couldn't get the new Drill Press, Milling machine, Gearhead Lathe and Cold saw in her car and I took the insurance off of the big truck to save money so I will have to wait for my Christmas list to be filled.  I did get a new Digital Camera and we were able to get all the kids (and Grandson) great Christmas gifts this year!! (Life is good) and I can wait.Happy New year to all! BE BLESSEDTimPS: looking forward to being our CMA chaplain this yearA rich man is not the one who has the most but instead one who needs theleast. Retired IUEC local 19AK Bush pilot,  Chaplain  CMA Chapt 26victor torchesMiller110v migDynasty 200dx (new in Dec 08)Hypertherm PM-45MM-252 (new 2/09)
GMT+8, 2025-12-29 18:31 , Processed in 0.110245 second(s), 18 queries .
