Small Portable Settling Torch from H.D.
发表于 2021-8-31 22:47:35 | 显示全部楼层 |阅读模式
I was H.D. today and saw which looks to me be a minatature but small settling torch set up for $ 300. Has anyone used this set up?How much do the bottles hold?I don't really understand how the torch's work but can that really cut through a lot of steele?I am use to the bigger ones on the truck. Thanks, Mike.
Reply:They can be usefull for light work.  You probably cut a 3/4 bolt or rod with it. I'd probably limit it to 1/4-3/8 plate. Your not going to cut very much plate with it. It will run out of gas pretty quick. It only hold 10 cu ft of acetylene and 20 cu ft of O2.Tough as nails and damn near as smart
GMT+8, 2025-12-29 18:31 , Processed in 0.077077 second(s), 18 queries .
