Lincoln zr8 reading 140 Hz at low idle
发表于 2021-8-31 22:47:32 | 显示全部楼层 |阅读模式
The title says it all. I replaced the idle solenoid on my ZR8 (ranger 8 ) and just wanted to check the rpm. went to check the Hz reading at one of the 115 volt outlets and the reading was 140 Hz AND that was just at low idle. the reading is around 500 Hz at high idle no load. what the heck am I doing wrong? thanks
GMT+8, 2025-12-29 16:40 , Processed in 0.103258 second(s), 18 queries .
