Looking for Lathe Chuck
发表于 2021-8-31 22:47:27 | 显示全部楼层 |阅读模式
I have everything to make a rotary positioner except something to hold the work. So I was thinking a lathe chuck would be just the thing...  If you have one and are willing to part with it cheap lets talk Me!
Reply:do you happen to ahve access to machining equipment? i can probably make up some plans for you to make one just as good, if not better than you will ever find on the market.later,Andy
Reply:nope... Me!
Reply:How big?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by Me!I have everything to make a rotary positioner except something to hold the work. So I was thinking a lathe chuck would be just the thing...  If you have one and are willing to part with it cheap lets talk
Reply:Ditto the auction... Find a machine shop going out of business (lots of em these days)Or try this link: www.bidspotter.comThe best things in life all come on a stick!
Reply:Originally Posted by zapsterHow big?...zap!
Reply:Originally Posted by denrepWhat other ingredients are you using?I need to build one myself. Right now, I have a bench full of stuff I'm evaluating. I just centered this bearing, thinking I would use it as the hub.
Reply:Originally Posted by Me!Well I have several worm drive motor units and a few options for a variable speed drive, the foot pedal is the part that I don't have but there are several options on the market.  I was going to use a large copper "Brush" rubbing on the  chuck shaft fore the ground.
Reply:Let me ask my boss..You saw the place..There is everything everywhere..I'll get back to ya.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterLet me ask my boss..You saw the place..There is everything everywhere..I'll get back to ya.....zap!
Reply:Consider using a large copper braid strap for ground rather than a "copper brush."  You arrange the strap so it can wind up at least 360 degrees before tightening and rig up a switch or alarm to avoid continuing to wind up the strap after it has tightened.  Pretty simple.  Since you will rarely need more than 360 degrees of rotation in a welding positioner before resetting things, the limited rotation is not a problem, and you will get much more reliable and consistent ground connection with no arcing like you would get at the wiping contact of a homemade copper brush.  Additionally, the solid, bolted ground you will get with a braided strap will minimize the tendancy for welding currents to get to ground via your bearings or gears, which is destructive.If you do go with a lathe chuck, be sure to get one with 4 independent jaws, not a chuck with three scroll-driven jaws.  A 4-jaw chuck is a little slower to use on round work, but is MUCH more versatile and will allow you to grip an irregular work piece and to center any desired part of an irregular work piece.awright
Reply:i'm sure you all have seen this before, but here's a place that specializes in this exact thing...http://www.pwsweld.comthey give away free catalogs... mine is on it's way now. they are probably pretty expensive, but an option none-the-less.later,Andy
Reply:Hey Me,Go to www.hgrinc.com .  That is the link to HGR Indudtrial Surplus in Cleveland, Ohio.  If they don't have it, you don't need it.  Go to their site, check out what they have and if you find something you like call them and ask for Mike Metzger.  You can even haggle with them,  They will ship UPS.I recently bought a Bridgeport J-head series one mill there for $1,400.00 that they were asking $2,000.00 for and it was probably worth at least three grand.  They are open weekdays 8 to 5 and one Saturday a month.  It's 11 acres under roof.  The place is like Disney World for electro-mechanical motor head geeks.  I am sure you will find a chuck there for less than you could most other places.DaveDave B.E-MAIL:  [email protected] PAGES:  www.wfmservice.comwww.rides4rides.comwww.pvpmedia.com/53f100.htmDad always said, "If it ain't broke, don't fix it."I say, We can make it better.
Reply:System glitch in this thread yesterday...hopefully ok now.BethBeth AdministratorWeldingWeb.com
GMT+8, 2025-12-29 18:31 , Processed in 0.095079 second(s), 18 queries .
