Need a Argon hose whip
发表于 2021-8-31 22:47:23 | 显示全部楼层 |阅读模式
I need a new hose to go from the flow meter to the solenoid on my TIG machine. Anyone have a good online source for a new hose whip? I would like to get one pre-made like the old one...1/4" male pipe at the flow meter and has the gas fitting (same as the TIG torch line) on the other end. Eight feet would be perfect.
Reply:Some members buy from these guys, USA weld in Elk Grove, Illinois http://www.usaweld.com/Gas-Hose-p/hose.htmhttp://www.ebay.com/itm/Gas-hose-Arg...item20c735723bhttp://www.weldfabulous.com/p-75331-...ion-12-12.aspx
Reply:I would make that up with barbed fittings and clamps. Easy to do and your LWS probably has everything you need.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:It should have the same inert male fittings on each end. An LWS may have one and if not should have the fittings to make one out of single line green hose.
Reply:Originally Posted by Welder DaveIt should have the same inert male fittings on each end. An LWS may have one and if not should have the fittings to make one out of single line green hose.
GMT+8, 2025-12-29 16:51 , Processed in 0.105736 second(s), 18 queries .
