Sourcing stainless rectangular tube
发表于 2021-8-31 22:47:22 | 显示全部楼层 |阅读模式
Hey guys,I'm located in middle Massachusetts, and I'm having a tough tube finding a supplier of stainless rectangular tube,I tried Sullivan's (Worcester/Holyoke) and they don't even carry it, nor can they order it, I found this strange because they stock almost anything you can think ofI need roughly 10' of 2x3x1/8, the wall thickness isn't critical, but the thicker the better.Anyone ever use the online metal suppliers? Their prices remind me of buying from home depot out the like (read: extremely over priced) I haven't tried central steel, or my personal favorite, Worcester county welding, but it seems to be a tough to source stock, I could also probably get away with 2x2 square tube as well. any idea's?Miller Spoolmate 200 w/t S-52 WirefeederMM 211'09 Miller Trailblazer 302
Reply:Have you tried ordering through a local welding/fab shop as part of his normal resupply?  (For a reasonable up-charge, of course.)30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Jerry's approach often works for me. Being stainless I would also try a food processing plant as a source or suggested supply outlet they may know. In this area we have several ranging from soft beverage/ brewery plants to veg packing plants to manufacturers of SST transport (milk/food grade 88) trucks. Ask your welding supply house who is using CNS G3077-86: for stainless steel wire rod. CNS G3076-86: Chances are they are welding stainless and have a supplier. Good Luck
Reply:Originally Posted by storemanHave you tried ordering through a local welding/fab shop as part of his normal resupply?  (For a reasonable up-charge, of course.)
GMT+8, 2025-12-29 16:51 , Processed in 0.069093 second(s), 18 queries .
