What sort of wierd modification is on this Idealarc?
发表于 2021-8-31 22:47:21 | 显示全部楼层 |阅读模式
someone please clue me in on why this Idealarc has a motor mounted on top?? http://seattle.craigslist.org/tac/tls/4832088695.html
Reply:Remote control.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Power amperage adjustment? $250 for an AC/Dc Idealarc isn't bad though. hopefully what ever was done to it didn't wreck anything..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Remote control amperage adjustment SteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250SteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Now that's thinking out of the box! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Spend the $5.50 + gas, and go buy that welder. Then buy these, and get a bottle of argon, and you can Tig weld as well. Or you can use my Tig rig. http://www.ebay.com/itm/170622076947...%3AMEBIDX%3AIThttp://www.ebay.com/itm/140514184508...%3AMEBIDX%3AITDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:To go from 0-60 in 3 seconds.
Reply:That thing is legit - belt guard and all! Just when I think I've seen it all....BAM!!!!! That just happened!
Reply:i thought you guys were joking around about this "remote control" stuff.went back and looked at the pictures and. . . .. . . i'll be darnedbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:It looks like a gearmotor so couyld have low rpm for adjusting amps--  Is this a good welder? how much input power does it need, and how much does it weigh? Space is limited , so I have been thinking about an inverter type... but old is cool!
Reply:Interesting. V belt pulleys and belt. I'd like to see it work. These are very good single phase stick welders. I also scratch start dc tig with mine.That's a very good price for an ac/dc unit.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I run my Idealarc250 on a 50 amp circuit. The price is reasonable for a legendary welder Here's mineSent from my iPad using TapatalkSteveLincoln IdealArc 250Lincoln SA200 1966 RedfaceSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Arguably the best conventional single phase welder you can buy! Lincoln still makes them and they cost about $2500. They weigh 350 lbs. less the remote set up or running gear. $250 is a steal if it works.
Reply:Not that far fetched. check out http://www.up-ten.com/. same principal.Miller Big 40GMiller HF-251 D High FreqVictor OA Lincoln 135 MigMK 3A CobramaticBridgeport J HeadCronatron OxylanceRadnor ACAG TorchWeldcraft TIG Torches1 blown knee and two 5 Gallon pails away from being a hero.
Reply:Originally Posted by stoneaxeIs this a good welder?
Reply:That gear motor setup is worth a few bucks in and of itself."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:i have a couple at my shop minus the remote. awesome machines that take tons of abuse and neglect but still weld like new. i always said welders were ingenious and this proves it once again.i.u.o.e. # 15queens, ny and sunny fla
Reply:I'd jump on that one quick. Look at the case and face plates. That machine has led a relatively pampered life. Great price too for all of that.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:I'm posting the pictures from the add before it's taken down so someday when our grandkids are reading our memoirs on here, they won't think we were all drunk.
Reply:Originally Posted by PipelinerI'm posting the pictures from the add before it's taken down so someday when our grandkids are reading our memoirs on here, they won't think we were all drunk.
Reply:Lincoln made a remote for the TM 300 to TM 650. with a Internal motor, I have it with a burned out motor.Set up with a bike chain drive.
GMT+8, 2025-12-29 16:52 , Processed in 0.070444 second(s), 18 queries .
