bandsaw blade stock? Where to Buy?
发表于 2021-8-31 22:47:18 | 显示全部楼层 |阅读模式
Where do you all buy your blade stock at?  I just got a larger bandsaw and a blade welder so now I need to buy some blade stock.THx.
Reply:I use pre welded blades.  I know of a lot of larger companies that do too because of the labor and maintenance and upkeep costs offset buying a prewelded blade.As far as general stock, I use Lennox Die-Master II blades.   There are others,  but they cut very well and I think you might be able to buy them in bulk lengths.  Fastenal should be able to get you anything you need.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:where did you get the blade welder and lets see some pics
GMT+8, 2025-12-29 16:51 , Processed in 0.076826 second(s), 18 queries .
