millermatic 35
发表于 2021-8-31 22:47:18 | 显示全部楼层 |阅读模式
anyone have one, know of them, opinions? I may work a deal to trade my pexto 36" shear for one, is it worth it?
Reply:http://www.millerwelds.com/about/1971.htmlCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Don't know what the Pexto is worth, but the MM35 was Miller's first attempt at a one-piece welder/feeder combination. Did not really have a wire feeder inside-had a motor running through a rheostat. No feedback. All parts are available in general except for the drive motor assembly. Their next model was a MM200 and they knocked it out of the park with this one. You will be much happier if you can locate MM200, and it will accept spoolgun. weldersales
Reply:I've got both a millermatic 35 and a 200 and i will have to agree that the 200 is a much better machine!   The 35 has 6 plugs for the current adjustment whitch is kind of a pita  whereas the 200 has a high and low plug and a 6 tap switch to control the current... much better system!   The wire speed control on both of these machines has given me trouble in the past but both were easy fixes.  These machines are both very well built and will give you a lifetime worth of use with minimal maintenance,  in fact the 200s in my area are somewhat of a sought after item from what my lws tells me.  Go get yourself a MM200,  you wont be disapointed!  Good luck,  Matt
Reply:this is the one, whatcha think? Attached Images
GMT+8, 2025-12-29 16:51 , Processed in 0.072096 second(s), 18 queries .
