snap on YA5550 plasma cutter
发表于 2021-8-31 22:47:17 | 显示全部楼层 |阅读模式
hey all, i just picked up a snap on ya5550 plasma cutter.. i got it for a great price $ 000!!!the guy i got it from said it was a mystery machine, and that it only worked when it wanted to.. well so far i have not been able to get it to work.it powers on.. and when on SET UP  air flows.. the air regulator says 65-70 psi, so i know i am GETTING ENOUGH AIR.. when you take it off of set up and try to cut. i don't get an arc or any air flowing. the consumables are good and i know the trigger works cause i tested it.the lights for the cutting power and trigger opperation do not light up.when on set up the trigger light is on.i emailed snap on and they sent me a users manual and parts list, but it has no diagnostics section.this is my first plasma cutter, though i have used one many times.WHAT DO YOU GUYS THINK THE PROBLEM COULD BE
Reply:Sounds like it's one of those times where it "don't want'ta work".Maybe it's heard that with the oncoming Obamanation, you get taken care of whether you want to work or not.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Get yer money back, you got took.
Reply:Try cranking the regulator all the way up, I have the same machine that had the same problem and it worked on mine. There is a second regulator inside the back where the air line goes in that limits the air to about 80 psi  my gauge said 70 psi and it acted the same, upon closer inspection the gauge is reading 15-20 psi high.Hope this helpsBill
Reply:Can you post a pic of the machine and the torch?  I have an idea what's wrong, but need to see the machine first.  If you can't post apic where is the machine made? ITaly?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:The YA5550 was a Century/Cebora/Clore machine made in Italy.It has an interlock preventing current flow if the torch isn't assembled correctly, and another preventing current flow, if the pressure is too low.You need a minimum of 65PSI measured while air is flowing.Setting your pressure to 90 with the machine off is a fine starting point.  The manual should show that its safe up to 120PSI.BTW, one quick call to Snap On, and you can get the manual very easily.  I've done this a few times, and they are happy to email you a .pdf file, fax it, or even mail it to you.
Reply:If this is the torch head I am thinking about, the wire to the switch inside the handle has been known to unplug itself.  Open up the head and verify that both wires to the switch are on their spades.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-29 16:50 , Processed in 0.075206 second(s), 18 queries .
