RV antifreeze in TIG torches
发表于 2021-8-31 22:47:12 | 显示全部楼层 |阅读模式
A recent thread had a post that stated RV antifreeze was not rated for thermal transfer by Recochem - one of the manufacturers of RV anitfreeze.I emailed the company (Recochem) and here is the response:RV plumbing antifreeze contains ethanol and if heated the solution will release ethanol vapours which are flammable, this is why Recochem does not recommend the use of RV plumbing antifreeze as a heat transfer fluid.Hope this helpsthanksRobin Le SageRecochem Inc. 8725 Holgate Crescent, Milton, Ontario, L9T 5G7Directeur, Conformité et Informations TechniquesCompliance and Technical Information Manager
Reply:I use the prestone RV antifreeze and it does not list ethanol on the label, the WM brand does.   So I used the Prestone stuff for the last year and had no problems...  I am not saying do or don't, just sharing my personal experienceTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Cool, figured there was a reason people use it without problems Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-29 16:52 , Processed in 0.077260 second(s), 18 queries .
