Pipefitter 2 hole flange pins
发表于 2021-8-31 22:47:07 | 显示全部楼层 |阅读模式
I'm selling these for welding web members at $40.00 shipped. These are carbon steel 1 7/16 shaft with 1/2" stainless steel all thread. One side is knurled for easy tightening. I also have other sizes available and some solid stainless steel pins for special applications.I can also add a vial level (similar to the flange wizard pins) to one pin for a little extra $$Let me know if you have any questions. Pictures shown are s.s but the carbon pins are the same. Attached Images
Reply:Really nice looking!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Thank you!!
GMT+8, 2025-12-29 16:52 , Processed in 0.106152 second(s), 18 queries .
