Buzzbox Help
发表于 2021-8-31 22:47:02 | 显示全部楼层 |阅读模式
I have a buzzbox and was wondering if they made longer ground & electrode chords and if so where could I find them. Any help appreciated. ThanksLincoln AC-225 90 amp flux core
Reply:Easiest thing to do is get some Tweco type 1MPC male & female twist lock connectors and make extensions for what you have now.
Reply:+1. The cable can be picked up almost anywhere, even tractor supply. Throwing a DINSE, lenco, tweco, or some other kind of connector in there is probably the bast way to go.Miller Multimatic 255
Reply:Where can I find that online?Lincoln AC-225 90 amp flux core
Reply:http://store.cyberweld.com/cabcon.htmlCyberweld above for reference. But everyone sells them. Probably look at buying #2 welding cable.
Reply:If you don't want to spend for genuine Tweco these will work and about 1/2 price. http://www.atlweldingsupply.com/Weld...co_p_1753.html
Reply:Would this work? Attached ImagesLincoln AC-225 90 amp flux core
Reply:Yes but you will still need the quick connects.
Reply:If you have a good stinger and ground clamp you could save some $$$ and just buy the cable.  $107 + shipping for 100 ft of #2 cable vs $272 for what you linked.  http://www.electronbeam.com/December 2014 Pricing, EB-flex, Class K, Welding Cable..... Pricing changes monthly.6g (16 mm sq) EBT Part No. 31-PXL...... $0.47 per foot 4g (23 mm sq) EBT Part No. 46-PXL...... $0.73 per foot 2g (35 mm sq) EBT Part No. 69-PXL...... $1.07 per foot 1g (43 mm sq) EBT Part No. 84-PXL...... $1.30 per foot 1/0 (54 mm sq) EBT Part No. 107-PXL...... $1.63 per foot 2/0 (68 mm sq) EBT Part No. 134-PXL...... $2.01 per foot 2/0 (68 mm sq) RED, EBT Part No. 134-PXL RED...... $2.01 per foot 3/0 (85 mm sq) EBT Part No. 168-PXL...... $2.53 per foot 4/0 (109 mm sq) EBT Part No. 214-PXL...... $3.24 per footRestrictions apply (minimum length 25' per size/color). Place your order with "Customer Service" at 815-935-2211 to place your order. We accept major credit cards. Free shipping for US x 48 if order is over $250. UPS collect for lesser amounts.Check back weekly for our random "Weekly Specials", usually posted on Thursday.
Reply:Originally Posted by PipelinerYes but you will still need the quick connects.
Reply:Originally Posted by cole_977What are the quick connects?
Reply:Is the #2 wire the 2/0?Lincoln AC-225 90 amp flux core
Reply:Originally Posted by PipelinerUnless you go all the way back inside your welder (more trouble than it's worth) you need the Tweco type male / female connectors like in the photo above.  One side of the quick connects go on your existing cables, the other goes on the end of your new cables.
Reply:Yep, if you were just down the road I could have stopped and bought everything you need and have it hooked up welding right now in the amount of time we have been on here. You can just take your existing stinger and ground clamp off your existing cables and put them on the end of your new cables.  Then put your male / female quick connects on your existing cables and other end of your new cables.And #2 (2 guage) cable is what you probably want. 2/0 (ought) is huge.
Reply:Ok thanks for the help!Lincoln AC-225 90 amp flux core
Reply:Ok last question, do local welding supply stores normally carry this or is this something I should get offline?Lincoln AC-225 90 amp flux core
Reply:Not sure if this is to scale or not, but it will give you an idea of relative sizes..."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-29 18:50 , Processed in 0.110269 second(s), 18 queries .
