Put My XRA-gun in the 350P today and the machine is not seeing it. Worked fine lasttime I used it. Any ideas where I should look ? Thanks, B.J.
Reply:Originally Posted by bjanacekPut My XRA-gun in the 350P today and the machine is not seeing it. Worked fine lasttime I used it. Any ideas where I should look ? Thanks, B.J.
Reply:Operater error on my part. Reseated 14 pin connector and it works fine. B.J. error on my part reseated the 14 pin connector and it works fine
Reply:Originally Posted by soutthpawDid you go into settings and choose xr-a? Maybe it's sewing it as the Spoolgun as they are bestiality the same.
Reply:Originally Posted by OkieDave...best autocorrect ever!
Reply:Originally Posted by soutthpawYeah, Swype makes some crazy auto corrects.
Reply:Originally Posted by Ian DuffinYeah but it "learns" words that you use often...Why are you using bestiality so much in conversation
Reply:Originally Posted by nomoreusmcBetter question why do you care? |
