Certified gas pipe welder in Phoenix, AZ
发表于 2021-8-31 22:47:01 | 显示全部楼层 |阅读模式
Got a plumber friend who is in need of having some 3" gas line welded.  He will supply all the pipe, but needs someone who is certified and has all the necessary equipment to weld it all up.  The job will be in the NW part of the metro Phoenix area.  Anyone who is interested or knows someone who is certified in the area, please get in touch with me and I will pass on the information.
Reply:Contact John, he is in the North West part of the state. http://www.firstratefabricators.com/Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I will pass on his information, but the size of the job would probably not be cost effective for him to travel from Kingman to Phoenix.
Reply:May not work out then. John is big time, and doesn't work for peanuts.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:most service side gas pipeing is super low pressure the last time i seen 3" gas pipeing being welded on a large goverment building they were doing it with a tombstone in a wheel barrow right off of the over taxed spider boxes with 1/8" 6011.   was the equivelent of a seal weld.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-29 18:50 , Processed in 0.097696 second(s), 18 queries .
