What is a "AWS CWI SWRI-1 5 PIECE SET REPLICA WELDING SET" used for?
发表于 2021-8-31 22:47:01 | 显示全部楼层 |阅读模式
I found this on a local craigslist site.    I'm not sure just what one would use it for.   It seems the $400 price tag is awful high for 5 welded pieces and a copy of the test.   When I first saw it, my thought was that one could substitute these when applying for a cert.   That would not work, right? AWS CWI SWRI-1 5 PIECE SET REPLICA WELDING SET - $400The five-piece set is designed for training structural welding inspectors and welders. The samples include: 2 fillet-welded lap joints; 4-piece bend sample set; groove-welded butt joint. The variety of discontinuities exhibited includes: undercut, overlap and porosity. In addition, measurements of reinforcement and fillet weld size can be readily made.It is recommended for those preparing for the Practical (Hands-on) portion of the AWS Certified Welding Inspector examination. It is also excellent for other weld examination training programs requiring hands-one experience.
Reply:Includes a copy of the test?Not entirely ethical, but the test samples are interesting. If the samples help pass the test, and ROI is relatively quick, it would be worth it I guess.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:They are for measuring discontinuities and determining if they are allowable by code. It's part of the CWI test. The ones they give you on the CWI test are plastic. It would let you get familiar with measuring undercut and pinholes and such.
Reply:I have seen this ad before and my own "personal" take on the offer is that it is an over-priced scam. I believe that the un-informed individual will bite and waste a lot of hard-earned $$$$. But that's just my personal opinion however. Best regards, Allanaevald
Reply:Well, I wouldn't spend my money on it, but there is a market for it. I knew a welder once that had worked at a company where all he did was weld up coupons with flaws in them for trainee inspectors to practice on.
Reply:Hello TimmyTig, I am not saying that I don't see the need for this sort of thing. I am saying that $400 buckaroos for those samples is certainly over-priced, as you essentially stated. If you want to see "discontinuities" just take a trip over to your local high school or college welding/vocational/skills center etc. and you'll find any number of specimens that you can judge and critique and for a whole lot less money. Not disagreeing with you but definitely not buying into this particular offer. Best regards, Allanaevald
Reply:Originally Posted by TimmyTIGI knew a welder once that had worked at a company where all he did was weld up coupons with flaws in them for trainee inspectors to practice on.
Reply:I would and have just made my own samples for trainingSteve Hot Rod HooliganMiller Maxstar 200 STRCampbell Housfeld Flux Core 80
Reply:sell 'em for $400 ?
Reply:Those are from AWS, and can be bought new from AWS.  They cost about $430 new, so there you go.
Reply:Originally Posted by SupeThose are from AWS, and can be bought new from AWS.  They cost about $430 new, so there you go.
Reply:It most certainly does not.
Reply:When I did my level II UT we used some welded specimens with specific defects, these were bought from a company that specialized in them and cost a fortune.Some guys offered to try and produce some specimens with intentional defects.None of them managed to do it. I mean it is easy to produce a defective weld but if someone asks you to make a weld with sidewall lack of fusion 10mm long at a depth of 3mm from the back of the plate this is when it starts getting tricky.
Reply:Originally Posted by aevaldI have seen this ad before and my own "personal" take on the offer is that it is an over-priced scam. I believe that the un-informed individual will bite and waste a lot of hard-earned $$$$. But that's just my personal opinion however. Best regards, Allan
GMT+8, 2025-12-29 16:51 , Processed in 0.074729 second(s), 18 queries .
