Need Advice - Building Welding/fixturing table.
发表于 2021-8-31 22:47:00 | 显示全部楼层 |阅读模式
Hello Weldingweb,I am building a welding/fixturing table and I need help deciding on tooling. Originally, I was planning on use the same tooling that the Stronghand Buildpro table uses. However, I heard their tooling is "light-duty" and seeing as I am building my own table, I was wondering if there aren't any any better options for what I am doing. Ideas?
Reply:I just use a plate table. Tack things to it, flap disk the tacks off when done. Otherwise D&T a bunch of holes in it.
Reply:what the heck do you plan on building that requires heavier fixturing tools?
Reply:Look into an acorn table and the tooling used on them. Should be more than sufficient for your needs.Edit: Usually can be found at reasonable price, but transport may be problematic. Last edited by WyoRoy; 01-08-2015 at 08:24 PM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:EmpireWelding has one for sale in his thread.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-29 18:50 , Processed in 0.074326 second(s), 18 queries .
