sa200 rubber air hose... need a new one but where?
发表于 2021-8-31 22:47:00 | 显示全部楼层 |阅读模式
in the process of taking my machine apart I found that the air hose from the oil bath air filter to carburetor was half dry rotted apart... I was wondering what type of hose I could use as replacement from a napa type supply store instead of ordering from the companies mentioned many times on here... any ideas? ty
Reply:NAPA should have straight sticks of hose that diameter. You can always check online with BW Parts or Stumpf's Welding, they will have it for sureSent from my iPad using TapatalkSteveLincoln IdealArc 250Lincoln SA200 1966 RedfaceSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:make it easy on yourself, and get it from lincoln through your local welding store.    its a short little molded thing, and priced reasonably.
Reply:Originally Posted by then3wguyin the process of taking my machine apart I found that the air hose from the oil bath air filter to carburetor was half dry rotted apart...
GMT+8, 2025-12-29 16:50 , Processed in 0.099594 second(s), 18 queries .
