Idler
发表于 2021-8-31 22:46:59 | 显示全部楼层 |阅读模式
Got another question for yall. I have a 63 lincoln redface with a R-57 vacuum idler, it idles up fine but don't want to idle down sometimes I have to tap it to make it idle down. Now I have a miller with the same redseal engine that runs great with the newer electronic idler on it. My question is can i put the electronic idler on my redface and it work? Looks identical to the replacement one u can buy. I'm thinking it will but rather ask someone that knows for sure before I do it. Preciate all advice I can get.
Reply:Don't know for sure the answer to your question. But it sounds to me like it should work also. Maybe somebody who knows for sure and certain will give you a definate answer, soon.Just wanted to ask, where from in La. you are? I'm in the NW corner of the state, near Shreveport(but not in it, or even the same parish).
Reply:There are several different electric idlers being made for the SA 200s. In the threads listed below are a couple of threads dealing with fixing the R-57 idler too. All of the welder parts stores listed below have the electric idler kits to replace the R-57.http://hybriweld.com/?SID=7e0c524648...77c8e046faf61chttp://weldmart.com/http://www.bwequipmentrepair.com/http://billswelderrepair.com/SA-200.htmlThese are threads that contain valuable information about rebuilding or maintaining the SA 200. SA 200 Dis-assemblyhttp://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=19023Digital Multi Meter & Ohming Coilshttp://weldingweb.com/vbb/showthread.php?t=178071 Shunt Coil Change http://weldingweb.com/vbb/showthread.php?t=49665 http://weldingweb.com/vbb/showthread.php?t=168831 Removing the Exciterhttp://weldingweb.com/vbb/showthread.php?t=140751 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=140751&highlight=exciter+armature  "& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=140751&highlight=exciter+armature  "highlight=exciter+armature Operation & OCV http://weldingweb.com/vbb/showthread.php?t=265341  (you tube video)http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=27707 Front Main Seal & Speedy Sleevehttp://weldingweb.com/vbb/showthread.php?t=117031 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=117031&highlight=200+front+seal"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=117031&highlight=200+front+seal"h  ighlight=200+front+seal 1 Wire Alternator & Wiringpage 2 starting post # 44 http://weldingweb.com/vbb/showthread.php?t=117031 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=117031&highlight=200+front+seal"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=117031&highlight=200+front+seal"h  ighlight=200+front+seal PC Board Differencespost # 31http://weldingweb.com/vbb/showthread.php?t=38816 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=38816&highlight=200+ocv"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=38816&highlight=200+ocv"highlight  =200+ocv Worn Armature Commentator  http://weldingweb.com/vbb/showthread.php?t=152841 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=152841&highlight=200+ocv"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=152841&highlight=200+ocv"highligh  t=200+ocvGovernor Linkage Adjustmenthttp://weldingweb.com/vbb/showthread.php?t=172341 Pierce Governor Tear Down & Rebuildhttp://weldingweb.com/vbb/showthread.php?t=136081 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=136081&highlight=governor+rebuild  "& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=136081&highlight=governor+rebuild  "highlight=governor+rebuild Hoof Governor Tear Down & Rebuildhttp://weldingweb.com/vbb/showthread.php?t=136581 R-57 Idler Wiringhttp://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=29002 R-57 Idler Maintenancehttp://weldingweb.com/vbb/showthread.php?t=167491 http://weldingweb.com/vbb/showthread.php?t=183781 Grind Eze Wiringhttp://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=30413 Remote Rheostat Wiringhttp://weldingweb.com/vbb/showthread.php?t=301571 http://weldingweb.com/vbb/showthread.php?t=35225 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=35225&highlight=sa200+remote+rheo  stat"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=35225&highlight=sa200+remote+rheo  stat"highlight=sa200+remote+rheostatWater Seating Brushes http://www.aws.org/cgi-bin/mwf/topic...ting%20brushesF-162 & 163 Thermostat Installationhttp://weldingweb.com/vbb/showthread.php?t=83131Water pump Rebuildhttp://weldingweb.com/vbb/showthread.php?t=32321 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=32321&highlight=water+pump"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=32321&highlight=water+pump"highli  ght=water+pumpExhaust Manifold Stud Removal/Replacementhttp://weldingweb.com/vbb/showthread.php?t=97111Replacing Rope Oil Sealhttp://weldingweb.com/vbb/showthread.php?t=268641Lead Reelshttp://weldingweb.com/vbb/showthread.php?t=48478 HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=48478&highlight=lead+reel"& HYPERLINK "http://weldingweb.com/vbb/showthread.php?t=48478&highlight=lead+reel"highlig  ht=lead+reel http://weldingweb.com/vbb/showthread.php?t=208341 Short Hood Radiator Cap Part #shttp://weldingweb.com/vbb/showthread.php?t=84991 Marvel Carburetor Teardown & Cleaninghttp://www.johnsoldiron.com/M_S_TSX_Carb_part_2.htmlB&W Parts SA 200 Maintenance Videoshttps://www.youtube.com/channel/UCUL...LNfMqmA/videosOnly when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Thanks gizzard it is well appreciated. See that's why I listen and hang with older men i learn a hell of a lot more from them lol. When they pass on they take knowledge with them. They prolly forgot more than we know. Before they lay them down to rest I wish we could get all the knowledge out lol
Reply:Bistineau I am 30 miles north of Shreveport on hwy 1 ur not far from me at all you around haughton?
Reply:Originally Posted by Hoghunter74Bistineau I am 30 miles north of Shreveport on hwy 1 ur not far from me at all you around haughton?
Reply:Sweet place man im bout 1 min from black bayou the salvania has taken it over tho. Yes gizzardguts helped a lot it's good info to keep for my machine. He was big help. I appreciate the older hands that do help well most will help anyone but i watched and learned if ur cocky or think u know more than them then they won't and will be done with u then younger folks say they are ******* welders lol. I always love to listen and learn from them they can show u shortcuts and tricks that help a lot they been there done that lol.
GMT+8, 2025-12-29 16:50 , Processed in 0.107563 second(s), 18 queries .
