How can i bend 3/4 tubing?
发表于 2021-8-31 22:46:58 | 显示全部楼层 |阅读模式
How can i bend a 90* angle with 3/4 18guage tubing. I don't have a tubing bender and don't want to buy one because they cost alot. I tried bending it around a brake roader but it still kinked. Would a 3/4 conduit bender work? ThanksYa gotta spend money to make money!
Reply:You need a 1/2" bender for 3/4" tubing.  That is 3/4 in tubing 16g.  It did a good job for what I need.   Post 53http://weldingweb.com/vbb/showthread.php...+tubing&page=3
Reply:Shane, you can also try packing the tube, TIGHTLY, with sand. Make a wood plugs for each end, pound one in with a mallet, upend the tube and start filling. Have a small rod or dowel to help tamp as you fill, After you get about the botton 6-10 inches full of sand, start tamping the crap out of it. Take it all the way to the top, tap in the second plug. Try that. It will help if you clamp one edge of the start of the bend tight. I am not sure if you should heat your tubing or not. Try a test piece first.
Reply:18g should bend easily in a Conduit bender.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli118g should bend easily in a Conduit bender.
Reply:Tap,That does look good! Il'l check for a 1/2 conduit bender. Why do i need a 1/2 one and not 3/4, since the tubing is 3/4? ThanksYa gotta spend money to make money!
Reply:Originally Posted by welderShaneTap,That does look good! Il'l check for a 1/2 conduit bender. Why do i need a 1/2 one and not 3/4, since the tubing is 3/4? Thanks
Reply:For reference Attached ImagesA butterfly without wings, is just an ugly bug
Reply:There is a chart for the dimension of emt.http://www.elliottelectric.com/Inven...(CON)/EMT2.pdf
Reply:Thanks. Yea i got 3/4 od tubing. I saw some 3/4 conduit benders on ebay that seem pretty cheap. Also i have to do some notching too. Correct me if im wrong but, its 3/4 od tubing so i need a 3/4 holesaw right? THanksYa gotta spend money to make money!
Reply:i've heard of guys packing the bend point with sand to keep it from collapsing.. never tried it, but theoretically, it sounds good.http://kawispeed.com/ -moderator and tech deluxewww.myspace.com/trickortrack -cuz i have no life
Reply:WelderShaneI don't think you 3/4" conduit bender will work.  The od is over 1 inch.  Check the chart above Also search  conduit dimensions.  Perhaps somebody will step in here.Though the way I see it Conduit and Emt are used to carry substance (wire), thus the knowing the capacity is important.  It is measured like pipe.I do realize that typically pipe is measured id and structural tubing is od.  Seems conduit and emt are different id measured. I got my bender for less than 10 dollars handle second hand store.  Check craigslist and pawn shops.
Reply:WhiteHendrix RE: Sand Packing. This piece done with sand and a H-F Kinker, however, it is pipe, for which the bender was designed, not thinwall tubing. Note, there is some flattening in the curve. Attached Images
Reply:Originally Posted by cranestShane, you can also try packing the tube, TIGHTLY, with sand. Make a wood plugs for each end, pound one in with a mallet, upend the tube and start filling. Have a small rod or dowel to help tamp as you fill, After you get about the botton 6-10 inches full of sand, start tamping the crap out of it. Take it all the way to the top, tap in the second plug. Try that. It will help if you clamp one edge of the start of the bend tight. I am not sure if you should heat your tubing or not. Try a test piece first.
Reply:Shane,This is 3/4" Al tube. I can do the same with mild DOM or seamless CroMo.How many bends do you need?Rex
Reply:rode, Im not sure how many bends i need yet. Im designing a rear rack for an atv and i have a bunch of 3/4 tubing that im going to make them out of.Ya gotta spend money to make money!
GMT+8, 2025-12-29 16:51 , Processed in 0.074220 second(s), 18 queries .
