Help with Grinding Wheel video
发表于 2021-8-31 22:46:52 | 显示全部楼层 |阅读模式
I need your all's help in getting some video of an axe being sharpened on a big, old time  grinding wheel. If anyone has one and can shoot a quick 15 or 20 second video of the blade being sharpened, I'd really, really appreciate it. I can't shoot it myself because I don't have a wheel and the segment I'm shooting is a favor for a friend so buying one just for a 15 second or so shot is out of the question. So I thought you guys might be able to help. By the way... June 2nd Weld-o-Rama 2!!! I hope you can make it.
Reply:Sorry I can't make it to weld-o-Rama lol 49th state babyMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:That's too bad. I love it up there though. Beautiful, beautiful country.
Reply:yes it is but being a lifer I prolly don't appreciate it as much as some others  last November was shotty about -20 all monthMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:what is the welding aspect? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Re-building an edge that's been damaged. It's a visual comparison to days gone by when a big, heavy grinding stone was used to remove enough axe material to get a constant radius edge back compared to today when we can build edge beads to fuse with the metal substrate and then regrind it to a new edge without removing a big chunk of the axe metal itself.
GMT+8, 2025-12-29 16:52 , Processed in 0.072313 second(s), 18 queries .
