Miller 330abp
发表于 2021-8-31 22:46:51 | 显示全部楼层 |阅读模式
I was having issue getting an arch with my miller 330abp.  I realized that the machine is not groundedWould this cause issues with the arch?
Reply:If your machine is wired correctly, it should have the enclosure grounded to service. I would check the integrity of your ground clamp at the table and lugs. Then I would check the HF point gaps. Good luck, I am sure you will find the issue.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:How are you trying to run the machine?Stick or Tig?MORE INFO!!!We gotta start somewhere......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:is this a new to you machine or is it one you have been welding with and no issues till now?  Hands down, one of the best TIG/STICK machines ever made.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-29 16:50 , Processed in 0.099654 second(s), 18 queries .
