Penetration crosscut
发表于 2021-8-31 22:46:51 | 显示全部楼层 |阅读模式
Hey guys i was wondering how to get the weld penetration to show it's face when you crosscut your weld coupons I can see the line where the two plates are lapped but i would like to see the actual weld penetration like in some pictures on the netMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Polish then acid etch. there's a few big posts on here about it, search for acid etchingSent from my Galaxy Nexus using Tapatalk 2Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Acid etch with muratic? Like the same formula used to remove mill scale?Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Originally Posted by chevydylAcid etch with muratic? Like the same formula used to remove mill scale?
Reply:Yeah I don't need the hastle of getting another form of acid i did a search and a guy used heat and muriatic with great results. I just wonder if it will provide the same results on 304 ss using 308l fillerMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Muratic will work but is not the first choice.  Check the % on the bottle but I am betting there is a good chance you will not have to dillute.  The concentration that was used in the recent thread on here to do the mill scale removal would take a VERY long time if it did work.  I did one recently and I was using a 28% solution straight from the bottle and it took roughly 10 minutes submerged to get the results I was looking for.  When they say polished though it means just that.  Mirror shine finish.....not 80 grit sand paper.  Good luck!
Reply:Sorry to be a smartass but I know what polish means I spent about  14 hrs wentsandind up to 2000gr on some 22" alum wheels so that they could be clear powder coated Alaska puts some harsh winter chems on the road in the winter and it would oxidize the factory polish every winter and I'd have to buff them out every summer to restore the pretty look lol finally had enough took forever to get the tiny tiny mill marks outta the spokes and lipsNot sure the concentration of my acid i got it from home crapot and it says on the bottle new safer low fume formula Not at home so I can't check the % till I get home from work nxt weekLast edited by chevydyl; 05-24-2013 at 06:01 PM.Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Originally Posted by chevydylSorry to be a smartass but I know what polish means
Reply:I'm curious about this also.tagged acid etching"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I know mayne, I wouldn't waste the time with all that crazy sanding, I think it should be fine with a worn 120grit flapper ya know, lol im not gonna waste to much time just for that, well maybe I would aint got much else to do on my week off from work....the wife still gives me she-ite for 'buying that f***ing welder' lolMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Originally Posted by chevydylnew safer low fume formula
Reply:I just bought 2 gals. of muriatic acid at Home Depot.  Still 31.45% according to the lable.I got mine back in the garden/pool supply area.  They only sold it in cases of 2 ea. 1 gal. jugs, not individual jugs or bottles.
GMT+8, 2025-12-29 18:29 , Processed in 0.103426 second(s), 18 queries .
