#2 spool...what are the specs?
发表于 2021-8-31 22:46:51 | 显示全部楼层 |阅读模式
Trying to figure out either:How many pounds this spool isor what is it's diameter?http://www.amazon.com/Harris-Silicon.../dp/B00406SQJ2http://www.amazon.com/Harris-Silicon.../dp/B00406SQJ2Motorboating...in the Cleavage of the Tetons
Reply:Looks like a 4" spool, probably 2lbs. It says 2#.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Looks like right under the bar code it says........2lbs.Probably 4" dia.
Reply:ok, makes sense. looking for a 10 #spool of this (that will fit in my TA 181i unit)Thoughts?Motorboating...in the Cleavage of the Tetons
Reply:ebay?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:it doesn't seem to come up on any search I have been trying. Can you find it?Motorboating...in the Cleavage of the Tetons
Reply:http://www.ebay.com/sch/i.html?_odkw...e+mig&_sacat=0??Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Are you looking for the diameter of a 10# spool?  If so, it's 8".  Depending on the type filler metal, the 8" spool can also weigh in at 11# & 12.5#.The specs on your machine clearly states it will accept 4" (2#) and 8" (10, 11 & 12.5#) diameter spools.http://store.cyberweld.com/tharcfa18miw.htmlMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks, guys. Much appreciated.Motorboating...in the Cleavage of the Tetons
Reply:rideitHow many # . . .  what is it's . . ?If I were a drinking man I would order a Toledo  -  Starrett, with an Archimedes back. Gamble and J-W offered solutions without water; for esotericquantifications  -   duane55 is reliable.OpusLast edited by OPUS FERRO; 05-26-2013 at 03:07 AM.Reason: absent article
Reply:GobbledygookPrince of tidesCinnamon Cheerios, and duct tape!Motorboating...in the Cleavage of the Tetons
GMT+8, 2025-12-29 18:38 , Processed in 0.100795 second(s), 18 queries .
