Short piece of 7-8" od pipe?
发表于 2021-8-31 22:46:48 | 显示全部楼层 |阅读模式
Anyone got a short piece of heavy wall 7-8" od steel pipe layin around?
Reply:Originally Posted by jimmyedAnyone got a short piece of heavy wall 7-8" od steel pipe layin around?
Reply:Originally Posted by Donald BranscomPIPE is measured by the Inside diameter.TUBING is measured by the Outside diameter.7 inch PIPE is 7.625 OD or 7 5/8"OD 8 inch PIPE is 8.625 OD or 8 5/8 OD7 inch TUBING is 7 inch OD EXACTLY 8 inch TUBING is 8 inch OD EXACTLYBUT caution: the thickness of pipe and tubing is another issue.Schedule #'s 20,40, 80 etc,.,
Reply:How long do you want it?More than likely I will have something laying around.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I have about 35' of 8" laying around.
Reply:Originally Posted by SSS AngusHow do you figure?    Pipe Size is the accepted industry designation and does not refer to either the inside or the outside diameter (ID or OD) of a pipe or a fitting.http://academic.evergreen.edu/projec...abric/pipe.htm
Reply:"pipe" od is all the same reguardless of the wall thickness. the thicker the wall the smaller the id, the od stays the same.don't believe it?? take some sch. 30 and some sch. 40 and some sch. 80 and some sch. 160 and thread them (don't change the die setting) and then thead them on a fitting or flange. if the od's were different you could not get the die to thread onto the end of the pipe.trust me on this one.did not mean to steal the thread.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:How about this.."A piece of round steel..with a hole in it..that has a heavy wall thickness around 1/2" and is around 7 to 8" in diameter?"..  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Think maybe he has one by now! Being as how it was posted 11 months ago.
Reply:Originally Posted by zapsterHow about this.."A piece of round steel..with a hole in it..that has a heavy wall thickness around 1/2" and is around 7 to 8" in diameter?"..  ...zap!
Reply:Originally Posted by papa6512 in and under   is ID  14 and over  is OD  thickness does not matter.
Reply:I have plenty of stuff like that, go dig around in my back yard till you find what you want.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-29 18:29 , Processed in 0.158407 second(s), 18 queries .
