some small jobs i did this summer
发表于 2021-8-31 22:46:45 | 显示全部楼层 |阅读模式
refurbished a 1940s crop sprayer extened the boom about 9ft new tank and pump also one of my family racecar bumpers added angles tube supports to the middle cant find finished pic . nothing insane.everybody starts somewhere.
Reply:I guess that's OK for someone that's just a solderer.gotta start somewhere.
Reply:Even small jobs should be done well because it's the quality of work that is important and the quantity will follow. You are off to a good start.
Reply:idk why it says that and the small things will help you make a name with ppl and you  can build off of the work you do the boom was done cheap using 1 other old boom othe it  to save money so I usedwhat I could out of itLast edited by Welderjzimmerman; 09-10-2013 at 08:12 PM.everybody starts somewhere.
GMT+8, 2025-12-29 18:39 , Processed in 0.107245 second(s), 18 queries .
