Rubber Coated............
发表于 2021-8-31 22:46:43 | 显示全部楼层 |阅读模式
"Geez Fex..... another Domino thread..... enough already........"Yep....these are mild steel...... dipped in Plastic Dip paint from Lowe's......Dots are white using Q-tips and a really old can of white primer I found......Some guy at work said that gasoline removes mill scale....... which isn't really true.... but I just had to try.......Some pics of the set before plastic dip.... spray can version......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:The tools used to do the white dots.....Q Tips and a can of white primer that has rust in it....... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:And the final result...PIC One: Before the white dot treatment....PIC Two.... White Dot treatment..... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:That's almost nicer then getting your hands on a nice ivory set:beer:seabee78
Reply:Those things look awesome! I checked out the Guiness Records for domino toppling and did not see a single solitary steel one. Just for the hell of it...make up 50,000 or so and set a record that will likely stand forever!  POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Wonder what polished ones that have been flame colored would look like. The deep cobalt blue and the prple are two of the best looking colors.
Reply:Originally Posted by cold1Wonder what polished ones that have been flame colored would look like. The deep cobalt blue and the prple are two of the best looking colors.
Reply:Originally Posted by SMC WeldcraftThose things look awesome! I checked out the Guiness Records for domino toppling and did not see a single solitary steel one. Just for the hell of it...make up 50,000 or so and set a record that will likely stand forever!
GMT+8, 2025-12-29 18:38 , Processed in 0.242447 second(s), 18 queries .
