Automotive UHSS steel welding
发表于 2021-8-31 22:46:40 | 显示全部楼层 |阅读模式
I'm rebuilding a totaled Infiniti G37 sedan for my wife. It is hit on the passenger side, and the B-pillar (center post) is damaged low near the undamaged rocker. I have a used 1/4 cut for parts. The issue comes when sectioning UHSS. I believe this car uses 800Mpa steel (IDK what the alloy is yet), and there is no approved method for sectioning it. I'm thinking about sleeving it with 6 staggered 5/16" MIG plug welds per side and then MIG brazing the gap with SiBr. Any thoughts on welding or brazing this material?
GMT+8, 2025-12-29 18:39 , Processed in 0.180028 second(s), 18 queries .
