Help picking out a welder!
发表于 2021-8-31 22:46:36 | 显示全部楼层 |阅读模式
I am in the market of Purchasing a welder!  I will be doing TIG only on it, welding lots of stainless and aluminum.  Mainly on cars and things of that sort, it needs to be on wheels!  I would like a package that comes with the torch, pedal and everything.  I'm looking for something with good low range.  A machine that does Pulse really well.  And would like to be somewhere in the 4000 dollar range!  Thanks for the help!  Not sure if this is in the right spot.Last edited by headofahessian; 01-27-2009 at 02:11 AM.I WELD
Reply:id go with the dynasty 200 dx package$4385.00 at cyberweld Attached Images
Reply:i vote for the dynasty 200 dx too!!Ya gotta spend money to make money!
Reply:That is a VERY GOOD Package deal at that price esppecially if you can get them to throw in shipping.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:all orders from cyberweld have free shipping and no taxi got my spectrum 375, mm 251 30 a spool gundynasty 200 dx, victor contractor plus kit from themand in march im getting the new trailblazer 302 air pak and a 625 x or 875 x i like the 875 with its quick disconnect torchand the 625 cuts up to 7/8 and is only 23 lbs ether will run off thenew air pac
Reply:Could check out HTP too.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:where can I find the thread on why you made the choice on a thunderbolt? I am curious to find ouy why that was recomended over a mig. I saw one I think was about $50-&100 buck and thought about it. it was a bit rusty but I was still thinking about it. I have seen some real nice restorations of these older machines.
Reply:I found my Lincoln 175 to be a good choice for my Race car Fab shop. Price was right and being air cooled hasn't been an issue. Doing cage work and intercooler piping is pretty much a no brainer for the welder. Having less to hold and not having a the water cooler attached hoses is easier to get into tight spots of a car. If you were going to be welding hours straight then I would get a water cooled machine or if you are going to be welding up 1/4 or greater for 30 mins or longer.Race Car and Hot Rod Fabman
Reply:I vote for the Thermal Arc 185 ACDC.   I'm very happy with mine and it cost alot less than the Dynasty.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:HTP makes some nice gear. The Invertig 201 is AC/DC. and runs around $3000 IIRC
Reply:HTP gets my vote for bang for the buck.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I've been very happy with my HTP mig welder for the 15+ years I've owned it.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-29 18:30 , Processed in 0.072088 second(s), 19 queries .
