1991 Ford F-250 Diesel Dually
发表于 2021-8-31 22:46:25 | 显示全部楼层 |阅读模式
Anyone looking for a good base to build a welding truck on?  This truck started life as a standard F-250 pickup with the 7.3l diesel, automatic transmission, and non dually 3.73 drum brake rear axle. At around 80,000 miles I added a Hypermax Turbocharger kit and a Powerstroke intercooler bringing the horsepower up significantly. At 100,000 miles I replaced the automatic with a 6 speed manual transmission from a '99 Powerstroke Super Duty. I also swapped the rear axle for a completely rebuilt one from a '99 E-350 dually ambulance. This Dana 70 HD gave the truck rear disc brakes, 4.10 limited slip, and dual wheels. I used Arrowcraft spacers for the front wheels, and a brand new set of Alcoa Classic dually wheels. The truck still has the original paint, but it's getting pretty dead. It's never had any bodywork, and the only dent is a very small one on the tailgate. Truck comes with the Leer cap as shown in the pics. The truck currently has about 120,000 miles on it and runs great. It fires up instantly even in the cold temps we've been having. I pulled a 9500lb trailer to NY and back and was able to break the speed limit on any of the long mountain pulls on that trip - and I averaged 13mpg doing it! It pulls very strong! Peak boost is about 14psi on a hard pull and the EGT's peak at 1200. I am only the second owner and bought it with 34,000 miles on it. It's always been a southern truck that hasn't seen salt, and the underside shows it. I am an individual selling this truck - not a used car lot! The only reason I am selling it is I now have kids and ended up getting a crew cab superduty so we could all go in the truck. Looking for $4000.00
Reply:She's a sharp looking truck TF! Good luck on your sale for a clean heavy haulin' truck.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I sent you a pm
Reply:Do you still have the truck?I am very interested!!
Reply:Please tell me its not two wheel drive
Reply:Sharp truck!   Interesting rear fenders on it, look skinnier than normal dually fenders.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Yep - it's 2 wheel drive.  4 wheel drive for my needs would be a total waste - I just don't ever need it.The fenders are made by Lund to give a non dually a dually look.  I found them on Ebay when I went to dual wheels.  The stock dually beds are made different, so normal dually fenders would not work.  I also find the normal dually fenders on this era truck rather unattractive - way bigger and more square than they need to be.  The nice thing is these flares can easily be removed if you wanted to go back to a non-dually.
GMT+8, 2025-12-29 20:44 , Processed in 0.119183 second(s), 18 queries .
