Oak, birch and steel dining table
发表于 2021-8-31 22:46:22 | 显示全部楼层 |阅读模式
center is birch ply, edges are red oakstained birch ebony and the red oak natural, silver paintdesign:frametop progresstogethernext...
Reply:coat or two of stain finished stainingjointin placeNext up are two benches.
Reply:It's actually pretty sturdy.  I was worried about it before I had the top done, but once it was mounted there is hardly any movement.
Reply:Nice Work!
Reply:Looks good!!
Reply:Nice job, i like the color pattern...
Reply:Great job on the table. Looks great and very sturdy. Like the wood combination and the dark stain. ________________________-www.sawblade.com
Reply:That is a perfect project! Awesome work!PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Thanks for the compliments, guys!
Reply:Wow!   Nice work, both woodworking and welding.
Reply:That's a great looking table!JackFort Loramie, OhioMilermatic Autoset 180
Reply:Very nice!Now for some matching chairs?Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Originally Posted by app-ironworksllcVery nice!Now for some matching chairs?
Reply:Originally Posted by jakkylTwo benches next, maybe make some chairs later on.
Reply:Looks good the color looks amazing. I had made a timber dining table few months ago which has almost the similar color.
Reply:Clean and elegant. Wicked good...POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Nice job! Are the benches going on th short or long sides???TimTimmetalcraft by mooseSoutheast Michiganhttps://www.facebook.com/Metalcraftbymoose  Stupid Hurts!!
Reply:Wow.......Now I'm inspired to try and do one too......Your wood work is stellar......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Pretty good job of matching grain patterns on the glueup.  Hard to do on larger panels.  I used to build a lot of furniture."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Very Nice Work!1981 SA-250 D3.1521985 Cab & Chassis Chevy C30
Reply:awesome table
Reply:Very nice! How did you attach the the top to the frame?Millermatic 211 Auto-Set
Reply:Those are some clean lines between the two colors. Nice Table
Reply:Nice job.Did you let the bread board  ends float?Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:I notice you used 5W-30 on your furniture. I'm a 5W-20 guy, myself.  Great work!Very nice job.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Thanks guys!The benches are going on the long sides and then two chairs on either short end.  I've been slacking, so they still aren't done.I'll have to get pic of how it's attached.  I just used some scrap wood screwed into the bottom of the table that can turn and latch onto the angle iron.  It is quick and easy to remove the table top.I'm actually thinking of making another top to swap out for game night, with a felt top and raised sides.  Kind of like this table:http://www.geekchichq.com/the-portal-gaming-table.html
Reply:Great work!  How is the table top connected to the base?  I did not see holes drilled in the frame only picture.johnnyPLincoln Power Mig 256Lincoln 140 HDMiller Maxstar 150 STLHypertherm Powermax 45
Reply:Scrap pieces of wood I had, screwed into the top.  I can easily just spin these around and remove the table top, but they are secure enough to keep it from moving around.I think I used two on each long end and one on the short ends.
Reply:Finally got around to making a bench for this.Center is the same left over birch plywood from the table.  The legs are left over red oak from my floors.I put cut-to-fit felt pads on the legs to keep from damaging the floor.I am undecided whether I want to make another one for the other side or just have two chairs over there.
Reply:Very nice!ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:what did you use to keep from scratching the floor?Looks great !!!!!!!!!!!
Reply:Looking good!
GMT+8, 2025-12-29 18:50 , Processed in 0.067091 second(s), 18 queries .
