Something cool and old
发表于 2021-8-31 22:46:13 | 显示全部楼层 |阅读模式
Wanting to see if any one could help me out here found a welder at a local tool shop. mounted on a trailer looks old and cool to me but what do i know here are a few pics. Thanks for the help =John
Reply:I bought one of those new in 1980. DC generator, same arc characteristics as an SA-200. I think someone turned the mufflers 90 degrees. Mine pointed straight up. I dropped coffee cans over them for rainproofs. I got it to use around the house and then hardly every did use it. It was always easier to get my truck with the SA-200 on it. After I retired I used it to build a garage and a couple of big carports and then finally sold it.Last edited by Oldtimer; 03-10-2009 at 11:44 PM.
Reply:Find the unit Code# and plug it in here http://www.mylincolnelectric.com/Cat...ualsearch.aspx for the operations manual and here's http://onanparts.com/ (he's a member) where you can get information and parts for the engine if needed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I'll bet whoever had it didn't really want to let it go.  It looks well kept.  He even made sure to include the pull start rope."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-29 18:49 , Processed in 0.098597 second(s), 18 queries .
