3-Axis Welding Clamp--don't know how I lived without one of these!
发表于 2021-8-31 22:46:13 | 显示全部楼层 |阅读模式
Gents--I have no affiliation with Strong Hand Tools, but thought this is worthy of a post in the event you weld square or rectangular tubing up to about 2.250 inches.  The cool thing with this jig is the upright clamp.  This for me was a real time saver and things end up square in three directions.  I picked it up about at my local steel yard for about $160, it will pay for itself in the first few projects. their web site is:www.stronghandtols.com.
Reply:Yep those are great. I have 2 more budgeted in to the rack I am going to hopefully build in the spring. They are not cheap, but the are a time saver if you do alot of that sort of thing by yourself.
Reply:I tried one of those but found I could move a lot quicker with out it.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I was thinking of making something similar to that, and may still do so. At least looking at that one I have a few more ideas. Thanks .....
Reply:That tool's f'kn awesome man....where did you get it....never seen one of those but will  definitely search for a couple...thanks for sharing
Reply:ooops! sorry for asking from where you got the jig.....will search the site you uploaded...tanx again
Reply:Originally Posted by Broccoli1I tried one of those but found I could move a lot quicker with out it.
Reply:Those look great.  I have some smaller, cheap harbor freight clamps that will do the corners, though it won't do the  vertical piece that you have.  It did get my 2"x2" table top absolutely perfectly square when I built it.Mike
Reply:Originally Posted by Hammack_WeldingThat has always been my experience as well.  It is a good tool, and hold up great, I just always seemed to be able to get the job done just as well and faster without using it.
Reply:I see that it is in the new Northerntool.com cataloghttp://www.northerntool.com/webapp/w...5919_200355919This is the review from a buyer.  I am not sure of what he means in describing it not being level?----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------"I use this clamp for tacking together square tubing and angle iron. The 'threaded-rod-slide' push button speeds up the clamping time. You will have to put a 1" spacer on the other end of your work piece to make it level, or just buy two angle clamps, one for each end. The clamp is durable and well made."What is your level of technical expertise?: ProfessionalLast edited by TxDoc; 03-15-2009 at 12:39 AM.
GMT+8, 2025-12-29 18:50 , Processed in 0.112124 second(s), 18 queries .
