Ring Roller PLANS
发表于 2021-8-31 22:46:12 | 显示全部楼层 |阅读模式
I'm looking fror PLANS to build a ring roller.I see lots of threads and pictures of ones built but I want to go off a set of plans Plus where to purchase the rollers.I have done a bunch of looking and see great final products. I just want to cut drill and weld not design.
Reply:Reebs,If you give the size of material you want to roll and the size of "rings" you need, then it will be easier to know which direction to send you...Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Not sure: 1/4" x 4 flat. Round or square stock 1/2".I see me doing a bunch of smaller stuff. The above is the upper limit
Reply:Anyone
Reply:Harbor Freight sells an economical model probably cheaper than you can make one.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I have no plans Reebs but I am building one from this picture I found on the net. I think you find it pretty easy to copy.The last pic is the one I am making. Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:I understand lug but i like to build my own (if i can) and I hate harbor fright Jamlit I too like the looks of those.
GMT+8, 2025-12-29 18:50 , Processed in 0.117106 second(s), 18 queries .
