TIG cooling question
发表于 2021-8-31 22:46:11 | 显示全部楼层 |阅读模式
I see all this talk about cooling systems for TIG. Why and when do you ned this on a TIG?Century AC 100 stick (dead but trying to fix it)Everlast PA 160 STHhttp://www.riograndehatters.comhttp://www.texashatcleaners.com
Reply:welding for extended periods of time and/or higher amperage welding.  It also permits the use of a smaller torch (smaller than an equivalent amperage rated torch that is air-cooled). 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Just wear short sleeves. You stay cooler that way.Motorboating...in the Cleavage of the Tetons
Reply:if your air cooled torch gets so hot you cant hang on to it is a good indication your on the edge of needing a water cooled set up  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by rideitJust wear short sleeves. You stay cooler that way.
Reply:Originally Posted by smilexelectricNot even related to the topic..
Reply:A water cooled torch is smaller and lighter for a given urrent rating, you can use thinner gloves since the torch body wont warm up which greatly improves dexterity and control and therefore weld appearance/quality, and maybe most importantly the leads are much more flexible since there a lot less copper in the power lead.Welding/Fab Pics: www.UtahWeld.com
GMT+8, 2025-12-29 18:49 , Processed in 0.114147 second(s), 18 queries .
