XMT 350 MPa quick reference for Dig & Hot Start
发表于 2021-8-31 22:46:10 | 显示全部楼层 |阅读模式
Some of you folks out there might have a use for this sort of thing. I recently went through the manual and picked out some information to help with addressing some of the "hidden" features of these machines. This is a doc that I have laminated and affixed to our machines to give students the rundown on how to access and use these features. If anyone thinks that it is worthwhile for their use, please have at it. Best regards, Allan        XMT 350 MPa SMAW                                                           Arc Control (Dig)Press the Set-up Button so that the Arc Control Indicator is lit. Dig appears on the Left Display, and the corresponding dig setting appears on the Right Display.Rotate the Adjust Control knob to select the desired dig settings from 0 to 100.Dig control allows the arc characteristics, soft versus stiff, to be changed for specific applications and electrodes. Lower the dig setting for smooth running electrodes like E7018 and increase the dig setting for stiffer, more penetrating electrodes like E6010. Press the Set-up Button repeatedly until the Arc Control light goes out to return to the adjustment of the preset amperage.                                                       Programmable Hot StartPress the Setup button repeatedly until HOT.S appears on the left display. HOT.S adjusts the Hot Start Amperage to (AUTO) or from Min (1) to Max (50). (AUTO) automatically chooses a default amperage. The Min (1) setting results in no hot start amperage.Higher numbers result in higher start amperage. Press the Setup button again so HOT.T appears on the left display. HOT.T adjusts theHot Start Time to (AUTO) or from Min (1) to Max (50). (AUTO) automatically chooses a default time. The Min (1) setting results in no hot start time. Higher numbers result in longer start time. Press the Setup button to return to adjustment of preset amperage.I originally had all of this on a Word Doc. but for some reason I can't get it to load on here. Sorry, If you would like the actual doc. I can probably email it to you if you PM me. Regards, Allanaevald
GMT+8, 2025-12-29 18:49 , Processed in 0.105575 second(s), 18 queries .
