So I took a box of electrodes out to the barn to grind them, and decided to cut up some metal for a project while I was there. I had nothing to mark the metal with, so... yeah. I confess. I used a sharpened tungsten electrode as a scribe.It worked a treat too!I ground it extra when I was done.Everlast PA160-STH... and that's about it!
Reply:I use them as a scribe..Tooth cleaner..Digging out chips from my fingers...Whatever.They are CARBIDE afterall......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That is one of my best scribes. I have a whole pack of 1/8 pure that someone ordered and I never used. So I drilled a hole in a chunk of old broom handle and sharpened it to a good point. Never goes dull. Dont try and use it for a pick though.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Originally Posted by zapsterI use them as a scribe..Tooth cleaner..Digging out chips from my fingers...Whatever.They are CARBIDE afterall......zap!
Reply:Originally Posted by OscarWeird, I could have sworn they were tungsten...
Reply:I use my stubs after they get too short to clamp in the collet. A "pin vise" makes a perfect handle. Also keep one in my torch tip drill set just because the "pin vise" handle for those will also hold a tungsten scribe and is always handy when I forget to bring one along on those out of the shop excursions.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:On rusty stuff you have to learn to use your thumbnail as a scribe. works like a super fine soapstone. You gotta learn to use your other fingers as a right angle square to make straight lines tho. Comes with practice but works awesome I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Yep, I to have used tungsten for a scribe...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st |
